Old 07-29-2017, 10:21 AM   #1
FrankWest
FrankWest's Avatar
Default 1933 clutch pedal adjustment
I am preparing to adjust the play on my clutch pedal. There is far too much play and that is probably why I have having problems down shifting.
The service manual says to remove the clevis pin, unless I am seeing thing wrong under the car there is also a pin with cotter pin on the other side of the clevis, which is much easier to get at. Is there a reason that the more easily reached pin cannot be removed to adjust the length of the clevis bar?
FrankWest is offline   Reply With Quote
Old 07-29-2017, 11:40 AM   #2
weemark
Default Re: 1933 clutch pedal adjustment
it doesn't really matter what side you take off as long as you can adjust the length of the rod and get it back on.
weemark is offline   Reply With Quote
Old 07-29-2017, 12:17 PM   #3
FrankWest
FrankWest's Avatar
thanks..
Old 07-29-2017, 01:27 PM   #4
1931 flamingo
1931 flamingo's Avatar
Before you start messing with things,when down shifting are you double clutching?? Do you have the correct weight gear oil in the transmission??
Paul in CT
Old 07-29-2017, 02:36 PM   #5
FrankWest
FrankWest's Avatar
Paul in CT
I had very heavy oil in the transmission but I am changing to gear oil 85W90.
When stepping down on the clutch pedal, how much should the pedal move?
Old 07-29-2017, 02:58 PM   #6
FlatheadTed
FlatheadTed's Avatar
From the floor board to activation about 1/2 "free play .Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 07-29-2017, 03:15 PM   #7
Bob C
Page 33 of the Service Bulletins one inch free movement.
Bob
Old 07-29-2017, 03:28 PM   #8
lotsagas4u
Frank, go to Napa and get Sta-Lube 24238 gear oil, it is 140wt, you can put it in trans, and rear end.
This is the gallon jug number.
lotsagas4u is offline   Reply With Quote
Old 07-29-2017, 03:51 PM   #9
Lawrie
Lawrie's Avatar
Look back a few months,there was a GOOD post on Gl 4 and GL5 oil for the transmission,
I had been using the wrong GL5 stuff in my 33,changed it to a castrol GL4 and it shifts way nicer now.
Lawrie
Old 07-29-2017, 03:56 PM   #10
FrankWest
FrankWest's Avatar
Bob
I can push my clutch pedal all the way to the floor. 1 in indeed? Could my clutch be that much out of adjustment or just bad?
Old 07-29-2017, 04:11 PM   #11
lotsagas4u
Frank, do you have the correct clutch return spring? Pedal should move about a inch, before it starts to engage. Yes, it will go all the way to the floor.
Old 07-29-2017, 04:13 PM   #12
FrankWest
FrankWest's Avatar
Yes, I recently installed the correct NOS clutch and brake return springs.
I am drained the old gear oil and will buy some castrol GL4, what is the exact name of that stuff? is it castrol gear oil GL4...do I have to purchase this on line, something they usually don't carry in autozone type stores.
is this it Castrol Hypoy Gear Oil GL-4 SAE 80W-90
Old 07-29-2017, 04:41 PM   #13
FrankWest
FrankWest's Avatar
Lawrie
I don't think that oil is available in the us.
Old 07-29-2017, 05:07 PM   #14
Bob C
One inch free movement means you can depress the clutch pedal one
inch before the throw out bearing contacts the pressure plate fingers.
Bob
Old 07-29-2017, 05:10 PM   #15
weemark
you can use any GL4 oil, im sure there was a thread on here not that long ago about transmission oil, will see if I can find it
Old 07-29-2017, 05:26 PM   #16
Lawrie
Lawrie's Avatar
I will look on the lable of the stuff I used.
Lawrie
Old 07-29-2017, 05:29 PM   #17
FrankWest
FrankWest's Avatar
Bob
How do you measure that, just from the feel of it?
Old 07-29-2017, 05:46 PM   #18
Lawrie
Lawrie's Avatar
Oil I used is
Castrol Manual VMX 80W
for cars and light commercial vehicles requiring good low temperature shifting -APL GL-4
Lawrie
Old 07-29-2017, 06:16 PM   #19
FrankWest
FrankWest's Avatar
Oil I used is
Lawrie
Thanks, I will look for it.
Old 07-29-2017, 06:19 PM   #20
FrankWest
FrankWest's Avatar
thanks...I will try some of that too.
