The Ford Barn
-   -   1933 clutch pedal adjustment (https://www.fordbarn.com/forum/showthread.php?t=225646)
FrankWest 07-29-2017 10:21 AM
1 Attachment(s)
I am preparing to adjust the play on my clutch pedal. There is far too much play and that is probably why I have having problems down shifting.
The service manual says to remove the clevis pin, unless I am seeing thing wrong under the car there is also a pin with cotter pin on the other side of the clevis, which is much easier to get at. Is there a reason that the more easily reached pin cannot be removed to adjust the length of the clevis bar?
weemark 07-29-2017 11:40 AM
Re: 1933 clutch pedal adjustment
it doesn't really matter what side you take off as long as you can adjust the length of the rod and get it back on.
FrankWest 07-29-2017 12:17 PM
thanks..
1931 flamingo 07-29-2017 01:27 PM
Before you start messing with things,when down shifting are you double clutching?? Do you have the correct weight gear oil in the transmission??
Paul in CT
FrankWest 07-29-2017 02:36 PM
Paul in CT
I had very heavy oil in the transmission but I am changing to gear oil 85W90.
When stepping down on the clutch pedal, how much should the pedal move?
FlatheadTed 07-29-2017 02:58 PM
From the floor board to activation about 1/2 "free play .Ted
Bob C 07-29-2017 03:15 PM
Page 33 of the Service Bulletins one inch free movement.
Bob
lotsagas4u 07-29-2017 03:28 PM
Frank, go to Napa and get Sta-Lube 24238 gear oil, it is 140wt, you can put it in trans, and rear end.
This is the gallon jug number.
Lawrie 07-29-2017 03:51 PM
Look back a few months,there was a GOOD post on Gl 4 and GL5 oil for the transmission,
I had been using the wrong GL5 stuff in my 33,changed it to a castrol GL4 and it shifts way nicer now.
Lawrie
FrankWest 07-29-2017 03:56 PM
Bob
I can push my clutch pedal all the way to the floor. 1 in indeed? Could my clutch be that much out of adjustment or just bad?
lotsagas4u 07-29-2017 04:11 PM
Frank, do you have the correct clutch return spring? Pedal should move about a inch, before it starts to engage. Yes, it will go all the way to the floor.
FrankWest 07-29-2017 04:13 PM
Yes, I recently installed the correct NOS clutch and brake return springs.
I am drained the old gear oil and will buy some castrol GL4, what is the exact name of that stuff? is it castrol gear oil GL4...do I have to purchase this on line, something they usually don't carry in autozone type stores.
is this it Castrol Hypoy Gear Oil GL-4 SAE 80W-90
FrankWest 07-29-2017 04:41 PM
Lawrie
I don't think that oil is available in the us.
Bob C 07-29-2017 05:07 PM
One inch free movement means you can depress the clutch pedal one
inch before the throw out bearing contacts the pressure plate fingers.
Bob
weemark 07-29-2017 05:10 PM
you can use any GL4 oil, im sure there was a thread on here not that long ago about transmission oil, will see if I can find it
Lawrie 07-29-2017 05:26 PM
I will look on the lable of the stuff I used.
Lawrie
FrankWest 07-29-2017 05:29 PM
Bob
How do you measure that, just from the feel of it?
Lawrie 07-29-2017 05:46 PM
Oil I used is
Castrol Manual VMX 80W
for cars and light commercial vehicles requiring good low temperature shifting -APL GL-4
Lawrie
FrankWest 07-29-2017 06:16 PM
Originally Posted by Lawrie (Post 1506252)
Oil I used is
Lawrie
Thanks, I will look for it.
FrankWest 07-29-2017 06:19 PM
thanks...I will try some of that too.
