Old 08-02-2017, 10:26 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default Headlight wiring.
I have my bare headlight shell. new reflectors, bulbs, and all the other assorted pieces to connect to the wiring harness. The only problem is I have no idea how all these pieces fit together. Does anybody have a cutaway view of this?
TIA
Chris
1921 Runabout
1930 Tudor
Early 1930 AA
Old 08-02-2017, 10:34 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Headlight wiring.
So your reusing the lenses, cork gaskets, lens springs, rings etc?
Also I hope you got the new shells with the correct dome shape that brattons sells...otherwise your lights will be impossible to focus and be bright but dim at the same time.
if you got repo headlight sockets search on here about trying to make them less crappy before you install them.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-03-2017, 09:26 AM   #3
1955cj5
1955cj5's Avatar
I used the headlight sockets from Bert's along with a new harness and they all fit and work just fine.
You also need this part that slips into the socket in the bucket. It holds the connectors in place.
https://parts.modelastore.com/show_Product.asp?ID=4299
Les Andrews book has a cutaway view of the headlights..
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-03-2017, 11:01 AM   #4
Bob C
Look at page 84 of Bratton's catalog.
Bob
Old 08-03-2017, 11:15 AM   #5
Chris Haynes
Thank you!
1921 Runabout
1930 Tudor
Early 1930 AA
Old 08-04-2017, 02:41 PM   #6
KGBnut
KGBnut's Avatar
If you have the original sockets don't throw them out. I wasn't at all happy with the new replacements I got and ended up carefully rebuilding the originals. Most of the reproductions I have seen have issues with the contact being loose and not contacting the bulbs in the right place.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 08-04-2017, 10:58 PM   #7
Chris Haynes
I had bare buckets with not internal parts.
1921 Runabout
1930 Tudor
Early 1930 AA
