Old 09-28-2015, 12:32 PM   #1
Lon5ie
Lon5ie's Avatar
Default 47 mercury gauges
As I continue to sort through the parts from my auction car, I can't figure out what background color my 47 convertible gauges should be. The Merc book even lists two part numbers for the charge and temp gauges. The listed oil gauge is a 6M-9273 which appears to have a black background. The fuel is listed as a 6M--9280. Ammeter is listed as 6M-10850 or 59A-10850, temp is listed as 6M-10883 or 59A-10883. I see an oil gauge listed on EBAY as 6M-9273 and it has a black background, but then a ammeter listed as 6M-10850 at an old parts place has a silver background...UGH! anyone know or have pics from their 47 Mercury convertible?
Lon5ie is offline   Reply With Quote
Old 10-01-2015, 05:33 PM   #2
morrisgauge
Default Re: 47 mercury gauges
By 47' I believe you should have the black background. In general, one should be skeptical of eBay listings, etc. Do you not have the original gauges for confirmation?
morrisgauge is offline   Reply With Quote
Old 07-10-2017, 05:42 PM   #3
[email protected]
I have a 48 Mercury convertible. The speedometer, clock and gauges are "silver" or sort of a spun stainless. The surround for the gauges (behind the glass) is a satin black. On Fords, the surround is silver and the gauge faces are black. I believe the correct 6M 10883 gauge is silver. Because the black gauges fit fords, there are more of them around than the silver Mercury ones. When I got my car it had the wrong black Ford gauges in it. I found silver ones on eBay.
Bill in Conn.
patbill@megahits.com is offline   Reply With Quote
Old 07-11-2017, 05:59 AM   #4
47Merc
The back ground in the gauges in my 47 Merc coupe are black. The speedo and clock are a silver/gold color and I'm sure they are all original.
47Merc is offline   Reply With Quote
