Old 05-21-2017, 05:53 PM   #1
John Stone
John Stone's Avatar
Default What is this all about?
Finding weird things in engines always amazes me. Not sure what this is all about but it was a fix for a problem of some sort. Wonder if it worked.
John Stone is offline   Reply With Quote
Old 05-21-2017, 05:57 PM   #2
California Charlie
California Charlie's Avatar
Default Re: What is this all about?
I may be mistaken, but looks like something to redirect oil flow.
California Charlie is offline   Reply With Quote
Old 05-21-2017, 06:16 PM   #3
lindy williams
How does the front main, the front cam journal and the timing gear get lubricated with the oil rerouted like this?
lindy williams is offline   Reply With Quote
Old 05-21-2017, 06:30 PM   #4
Utopia Texas
Utopia Texas's Avatar
Isn't the oil going to flow over the dam at the same level with or without the added pipe?
Utopia Texas is offline   Reply With Quote
Old 05-21-2017, 07:39 PM   #5
1955cj5
1955cj5's Avatar
It kinda looks like someone had an accessory oil filter installed......but later took it out and left the feed pipe..
They when through some trouble to drill the casting for that bolt!
http://www.mikes-afordable.com/product/A6705F.html
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 05-21-2017, 07:49 PM   #6
denis4x4
denis4x4's Avatar
That's exactly what it is....looks like a part from an aFORDable filter that was part of an aftermarket valve cover.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 05-21-2017, 08:17 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
It also looks like someone might have installed rotators on the exhaust valves.
Either that or they found some mighty thick caps for the springs.
Old 05-21-2017, 09:55 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I'd guess that Rube Goldberg used to own the car---HA-HA-HA-HA-HA-----
Bill Goldberg
"THE ASSISTANT GURU OF STUFF"
Old 05-21-2017, 11:21 PM   #9
Drive Shaft Dave
I was thinking the same thing on the rotators, in any event ditch the pipe.
Drive Shaft Dave is offline   Reply With Quote
Old 05-22-2017, 05:16 AM   #10
Charlville
Charlville's Avatar
As noted, are you running an oil filter?
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 05-22-2017, 08:35 AM   #11
John Stone
John Stone's Avatar
There never was an oil filter installed on the engine.
I poured the mains 14 years ago but the rest was put together by someone else. I have no idea what the problem was that required this solution. I haven't taken it totally apart yet. I am curious about the front main. That area looks dry.
The rotators will be gone.
Old 05-22-2017, 09:20 AM   #12
1955cj5
1955cj5's Avatar
I for one will be interested to see what you find.....
Old 05-22-2017, 09:30 AM   #13
d.j. moordigian
d.j. moordigian's Avatar
I think the rotator's are a good deal!....keeps the valves from sticking!
Loose the the brass pipe....that's WRONG!!
d.j. moordigian is offline   Reply With Quote
Old 05-22-2017, 08:54 PM   #14
Drive Shaft Dave
I believe the purpose of the rotators was to prevent the valve's from burning.
Old 05-23-2017, 09:33 AM   #15
d.j. moordigian
I agree!...
But with so many posts about the valves sticking it could be a good idea. I've
been thinking about the one piece(solid) guides and after installing them, putting K-line "liners", that are Brass or Bronze(can't remember which) in them. They are an excellent product and I've used them for years..with NO
problems..
