![]() City:
Cape Cod
State:
MA
Price:
in ad
For this ad I have selected parts related to the engine. Here we go with the list: A-6344 Bolt only, for main bearing cap, $1.50 A-6347 Bolt only, for front & center main bearing $1.50 A-6327 Main bearing cap, needs babbit, $10 A-6551 Oil pump drive gear and case assembly, $10 A-9425 Intake manifold, high vacuum port 1931 type, fits all years, $30 A-9425 Intake manifold, no vacuum port originally, one drilled on top, $30 A-9425/30 Intake/exhaust together as removed from car, $50 A-6017 Timing gear side cover, $2 A-6019 Timing gear cover front, no 1928, but have 20 others, $5 A-9725 Accelerator linkage, no 1928, have other types , $20 A-8600 Fan, original, $15 A-8600 Fan, aftermarket type, $10 A-6395 Flywheel housing with enlarged cotter pin drain hole, $30 A-6200 Connecting rod core for rebabbit, with cap, $5 |
