The Ford Barn
-   Model-A (https://www.fordbarn.com/forum/forumdisplay.php?f=8)
-   -   Used Parts From Engine Area (https://www.fordbarn.com/forum/showthread.php?t=220247)
barnstuf 05-05-2017 01:05 PM
City: Cape Cod
State: MA
Price: in ad
Used original parts as removed from cars years ago, stored many years in the barn. They are unmolested, as is, no physical damage (unless indicated in ad) or excessive wear evident. Prices are + postage.
For this ad I have selected parts related to the engine. Here we go with the list:
A-6344 Bolt only, for main bearing cap, $1.50
A-6347 Bolt only, for front & center main bearing $1.50
A-6327 Main bearing cap, needs babbit, $10
A-6551 Oil pump drive gear and case assembly, $10
A-9425 Intake manifold, high vacuum port 1931 type, fits all years, $30
A-9425 Intake manifold, no vacuum port originally, one drilled on top, $30
A-9425/30 Intake/exhaust together as removed from car, $50
A-6017 Timing gear side cover, $2
A-6019 Timing gear cover front, no 1928, but have 20 others, $5
A-9725 Accelerator linkage, no 1928, have other types , $20
A-8600 Fan, original, $15
A-8600 Fan, aftermarket type, $10
A-6395 Flywheel housing with enlarged cotter pin drain hole, $30
A-6200 Connecting rod core for rebabbit, with cap, $5
