Old 10-24-2016, 06:23 PM   #1
marko
Default steering wheel question
Can a 1942 Lincoln steering wheel be swapped on to a 1950 F1? Just curious.
marko is offline   Reply With Quote
Old 10-24-2016, 10:41 PM   #2
lodaddyo
Default Re: steering wheel question
is the Lincoln steering wheel splined? because the f-1 steering shaft is splined. I might be wrong but I would think that the Lincoln wheel is tapered and keyed
lodaddyo is offline   Reply With Quote
Old 10-25-2016, 09:48 AM   #3
Frank Miller
Frank Miller's Avatar
If you can locate a Lincoln steering shaft you can probably weld it to the steering box you have. This is done with the Model As using the later box.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 03-13-2017, 11:30 PM   #4
Jason in TX
Jason in TX's Avatar
Lodaddyo is correct. Lincoln wheel is tapered key, F1 is splined.
To mount my 42 Lincoln wheel, I cut about a foot off the top of a passenger car shaft (tapered key) and welded it to the cut down F1 shaft using a piece of angle iron to get the shaft straight.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
