Hello,
My car along the way was converted to sealed beam headlights. What all do I need to go back to stock? New trim rings, glass and bulb? Sent from my SM-N920V using Tapatalk
1931 Model A Victoria 1950 Mercury 8 Member: MAFCA, MARC, Northern Ohio Model A Club www.northernohiomodela.com |
You also need gaskets and reflectors. Buy the reflectors from Bratton's, Bratton's Ford Parts, (301) 829-9880. Buy the reflectors from Bratton's. Did I say to buy the reflectors from Brattons. They have the best reflectors and to the best of my knowledge no one else sells them. If you don't believe me, check the archives. Don't cut corners on the reflectors.
Charlie Stephens |
#3 | |
![]() Quote:
#4 | |
![]() Quote:
Charlie Stephens Last edited by Charlie Stephens; 01-01-2017 at 09:30 PM. |
This is the place below. The phone number listed by Charlie Stephens in his post may be newer and better.
Uvira Inc 310 Pleasant Valley Rd Merlin, OR 97532 Contact: William Atwood Title: President Phone: 541-956-6880 Website: Uvira Inc is the only company located at 310 Pleasant Valley Rd, Merlin, OR. 97532 ![]() Uvira is located in Merlin, Oregon. This organization primarily operates in the Detection Apparatus: Electronic/magnetic Field, Light/heat business / industry within the Measuring, Photographic, Medical, & Optical Goods, & Clocks sector. This organization has been operating for approximately 45 years. Uvira is estimated to generate $1,000,000 in annual revenues, and employs approximately 14 people at this single location. Sector: Measuring, Photographic, Medical, & Optical Goods, & Clocks Category: Search and Navigation Equipment Industry: Detection Apparatus: Electronic/magnetic Field, Light/heat Commercial Physical Research Optical Instruments and Lenses SIC Code: 3812, 8731, 3827 Name: Uvira |
Adjusting screw and spring :-)
I bought a nice pair of lights, original horn, and light bar on ebay about 12 years ago that had sealed beams installed. I think the original rims are on and fine to use, so you will need every part except the rim and bucket as far as I can see.
I don't have much experience with the sealed beam conversion, so maybe some other company made one where the rims also need to be changed. |
It depends on what was used in the first place. Some kits "hid" the sealed beam behind the glass lens.
I went through this process back in April, documented a lot of the procedure in this thread;
https://www.fordbarn.com/forum/showthread.php?t=193956 |
#11 | |
![]() Quote:
#12 | |
![]() Quote:
#13 |
I'll start a new thread
1931 Model A Victoria 1950 Mercury 8 Member: MAFCA, MARC, Northern Ohio Model A Club www.northernohiomodela.com Last edited by biggieou; 02-03-2017 at 12:54 PM. |
#14 |
This actually answers a question for me. I took my headlights apart to polish things up and found sealed beam bulbs inside. You would never know. The do work good too.
#15 | |
![]() Quote:
#16 |
I would think effectively having 2 lenses it would scatter light all over the place, I may be wrong though! Have you compared to properly built stock A headlights? Just curious...
#17 |
Haven't really thought about the double lens thing. Drive it plenty at night and the lights do work well. I was really surprised when I saw sealed beam bulbs in them. The conversion looks to be well made. There are adaptor rings and retainers. Everything fits over the stock lens' and rings. You can look right at them and still not see the bulbs inside.
