Old 01-19-2017, 08:24 AM   #1
JohnB15632
JohnB15632's Avatar
Default 31A S/W 4D TS Restoration (Doors)
Question,
In restoring the Model A doors, what is the recommended sequence for installing the window drive mechanism and the door latch mechanism?
Which should be installed first?
Thank you,
JohnB15632 is offline   Reply With Quote
Old 01-19-2017, 09:00 AM   #2
jw hash
jw hash's Avatar
Default Re: 31A S/W 4D TS Restoration (Doors)
door latches first, window lower stop rubber, window regulator, window felt leaving the top unhooked to install the glass, rubber glass bumpers, glass, than the rubber seal above the glass
jw hash is offline   Reply With Quote
Old 01-19-2017, 09:28 AM   #3
jhowes
Wow, This is the kind of information that is so useful on this site. I'm going to print it out and hang it in my garage. I will try to use the same procedure on my non-model A car. Thanks; Jack
jhowes is offline   Reply With Quote
