The Ford Barn
-   -   31A S/W 4D TS Restoration (Doors) (https://www.fordbarn.com/forum/showthread.php?t=213040)
JohnB15632 01-19-2017 08:24 AM
Question,
In restoring the Model A doors, what is the recommended sequence for installing the window drive mechanism and the door latch mechanism?
Which should be installed first?
Thank you,
jw hash 01-19-2017 09:00 AM
Re: 31A S/W 4D TS Restoration (Doors)
door latches first, window lower stop rubber, window regulator, window felt leaving the top unhooked to install the glass, rubber glass bumpers, glass, than the rubber seal above the glass
jhowes 01-19-2017 09:28 AM
Wow, This is the kind of information that is so useful on this site. I'm going to print it out and hang it in my garage. I will try to use the same procedure on my non-model A car. Thanks; Jack
