Old 01-01-2017, 11:04 AM   #1
mike42
mike42's Avatar
Default '57 Pickup jammed-up set screw for inside door handle
Okay.....I've moved on from inside door protectant to taking off a very bad inside door handle. The set screw is all jammed up from someone not taking the time to use the proper allen wrench and there is a broken drill bit also in there ! Any secrets on getting the handle off ?
Thx....Mike
mike42 is offline   Reply With Quote
Old 01-01-2017, 11:44 AM   #2
Ole Don
Ole Don's Avatar
Default Re: '57 Pickup jammed-up set screw for inside door handle
OUCH! It may be time for a saw. Or a die grinder with a saw blade.
Ole Don is offline   Reply With Quote
Old 01-01-2017, 01:03 PM   #3
mike42
mike42's Avatar
Don....yeah ouch........I'm thinking about using my reciprocating saw to cut through the set screw area. I really can't think of anything else to do. We'll sethx
Old 01-01-2017, 06:54 PM   #4
frank long island
frank long island's Avatar
if you can get a cut off wheel in and cut the center of set screw or a die grinder with a pointed bit in the center a recip saw may be to violent maybe try just a hacksaw blade or a dremel tool I would plan on buying a new handle good luck
frank long island is offline   Reply With Quote
Old 01-01-2017, 07:22 PM   #5
bobss396
bobss396's Avatar
Kiss the door handle goodbye. An abrasive wheel would be my weapon of choice. You may mar up the regulator a bit but it will work.
bobss396 is offline   Reply With Quote
Old 01-02-2017, 03:19 AM   #6
mike42
mike42's Avatar
Guys thx........it just dawned on me that I do have a Dremel Grinder with several abrasive wheels. I already bought a new door handle along with a door panel I'm going to cover.
Thx ......Mike
Old 01-02-2017, 12:32 PM   #7
mike42
mike42's Avatar
Frank and Bob.....
Took my reciprocating saw and cut off the handle grip. Then took my Dremel and cut a deep slot through the center of the set screw.....bingo....the handle fell off !
Thx for the suggestions !
Old 01-02-2017, 05:09 PM   #8
frank long island
that's what we're here for, many of us been there done that
Old 01-03-2017, 02:10 PM   #9
mike42
mike42's Avatar
Long Island.....your correct to have a bunch of guys like you !
Old 01-04-2017, 04:56 PM   #10
willowbilly3
Judicious surgical used of the cutoff wheel is an awesome talent to hone.
willowbilly3 is offline   Reply With Quote
Old 01-05-2017, 10:33 AM   #11
mike42
mike42's Avatar
It takes a steady hand....I drink Jack Daniels....!!
Mike
