The Ford Barn
-   Late V8 (1954+) (https://www.fordbarn.com/forum/forumdisplay.php?f=5)
-   -   '57 Pickup jammed-up set screw for inside door handle (https://www.fordbarn.com/forum/showthread.php?t=211834)
mike42 01-01-2017 11:04 AM
Okay.....I've moved on from inside door protectant to taking off a very bad inside door handle. The set screw is all jammed up from someone not taking the time to use the proper allen wrench and there is a broken drill bit also in there ! Any secrets on getting the handle off ?
Thx....Mike
Ole Don 01-01-2017 11:44 AM
Re: '57 Pickup jammed-up set screw for inside door handle
OUCH! It may be time for a saw. Or a die grinder with a saw blade.
mike42 01-01-2017 01:03 PM
Don....yeah ouch........I'm thinking about using my reciprocating saw to cut through the set screw area. I really can't think of anything else to do. We'll sethx
frank long island 01-01-2017 06:54 PM
if you can get a cut off wheel in and cut the center of set screw or a die grinder with a pointed bit in the center a recip saw may be to violent maybe try just a hacksaw blade or a dremel tool I would plan on buying a new handle good luck
bobss396 01-01-2017 07:22 PM
Kiss the door handle goodbye. An abrasive wheel would be my weapon of choice. You may mar up the regulator a bit but it will work.
mike42 01-02-2017 03:19 AM
Guys thx........it just dawned on me that I do have a Dremel Grinder with several abrasive wheels. I already bought a new door handle along with a door panel I'm going to cover.
Thx ......Mike
mike42 01-02-2017 12:32 PM
Frank and Bob.....
Took my reciprocating saw and cut off the handle grip. Then took my Dremel and cut a deep slot through the center of the set screw.....bingo....the handle fell off !
Thx for the suggestions !
frank long island 01-02-2017 05:09 PM
that's what we're here for, many of us been there done that
mike42 01-03-2017 02:10 PM
Long Island.....your correct to have a bunch of guys like you !
willowbilly3 01-04-2017 04:56 PM
Judicious surgical used of the cutoff wheel is an awesome talent to hone.
mike42 01-05-2017 10:33 AM
It takes a steady hand....I drink Jack Daniels....!!
Mike
