My brother bought a model B engine with a strange number stamping. The number is stamped on the flywheel housing, as B engines are, but the number is odd. This engine also has a raised boss on the left side, where the model A engine has the serial number stamped, but the boss is about 2 inches by 3 inches, and it is thick, and has two tapped holes in it. We are wondering if this was some industrial application.
#2 | |
![]() Quote:
I am not sure what made it 'industrial' compared to a stock engine. If you give me the whole number, I will add it to my list of unusual engine numbers on my web site. The boss with two threaded holes is for a vacuum clutch canister mounting which was cancelled before start of production. Is is commonly found on early blocks, but was never used for anything.
Try Ford Garage Search Last edited by forever4; 12-22-2016 at 04:49 PM. Reason: ☆AIB5001526 ? Really early! |
AB 5???? If that is AB followed by a number in the early 5,000,000 range it is a normal early B, early in 1932 with AB that was shortened to just B for most B's.
Early B's had several features to accommodate a vacuum assist feature that was planned but never produced. Tapped holes might relate to that? |
Thanks very much for the replies. My brother is happy.
The tapped holes Bruce is talking about are on a boss below the oil fill tube. The boss is approx. 2.5" x 3.5" (from memory) The other feature meant for the vacuum assist was on the firewall to mount linkage or ???
That will need to wait for a while. My brother is on vacation.
