The Ford Barn
-   -   Mystery model B engine (https://www.fordbarn.com/forum/showthread.php?t=211308)
2manycars 12-22-2016 04:29 PM
1 Attachment(s)
My brother bought a model B engine with a strange number stamping. The number is stamped on the flywheel housing, as B engines are, but the number is odd. This engine also has a raised boss on the left side, where the model A engine has the serial number stamped, but the boss is about 2 inches by 3 inches, and it is thick, and has two tapped holes in it. We are wondering if this was some industrial application.
forever4 12-22-2016 04:37 PM
Re: Mystery model B engine
It appears your number starts with ☆AIB5xxxxx, which is early 1932 industrial engine, but not with the heavy clutch.
I am not sure what made it 'industrial' compared to a stock engine.
If you give me the whole number, I will add it to my list of unusual engine numbers on my web site.
The boss with two threaded holes is for a vacuum clutch canister mounting which was cancelled before start of production. Is is commonly found on early blocks, but was never used for anything.
Bruce Lancaster 12-22-2016 04:38 PM
AB 5???? If that is AB followed by a number in the early 5,000,000 range it is a normal early B, early in 1932 with AB that was shortened to just B for most B's.
Early B's had several features to accommodate a vacuum assist feature that was planned but never produced. Tapped holes might relate to that?
2manycars 12-22-2016 07:15 PM
Thanks very much for the replies. My brother is happy.
Jim Brierley 12-23-2016 12:19 PM
The tapped holes Bruce is talking about are on a boss below the oil fill tube. The boss is approx. 2.5" x 3.5" (from memory) The other feature meant for the vacuum assist was on the firewall to mount linkage or ???
KUDZUVIPER 12-23-2016 12:36 PM
Please post pix of the boss area with tapped holes and of the vacuum clutch canister. Thanks, George.
2manycars 12-23-2016 12:44 PM
That will need to wait for a while. My brother is on vacation.
