Old 10-03-2016, 08:12 PM   #1
31Abone
31Abone's Avatar
Default Value Model B blaock NOS
Have a couple of B blocks one has no serial number stamped the other # DR79567 .from an estate of an airplane kit maker,the motor was to be used in airplane..babbitt looks new also 2 cranks and cams maybe NOS also..wanting to know value as a fellow wants to trade some A parts..see pics..looks like they were coated with oil or geeese..the one looks NOS to me with no rig at all and bearings look like never been run.....sc
31Abone is offline   Reply With Quote
Old 10-03-2016, 08:33 PM   #2
Bruce Lancaster
Default Re: Value Model B blaock NOS
Do a bunch of dimensional investigation! B's used in USA production had no serial on block. The DR # is not a Ford serial...may well be the ID of a rebuilder. Measure everything and see what diameters are standard. You may have just very clean parts ready for assembly but not new.
Old 10-03-2016, 09:37 PM   #3
DougVieyra
DougVieyra's Avatar
Be careful - some sellers interpet NOS to mean : No Obligation Sucker, while others interpret NOS as Not Old Stock. It is getting increasingly more difficult to actually find NOS meaning New Old Stock.
DougVieyra is offline   Reply With Quote
Old 10-03-2016, 09:49 PM   #4
Charlie Stephens
It is not entirely impossible that living in Southern California you have a NOS Model B block. I have one and have heard of two others. Ford Parts Obsolete uncovered a warehouse in Poland with several hundred of them (they were all in pieces) in the sixties and shipped them over. They were intended as engines for Russian military vehicles.
Charlie Stephens
Old 10-03-2016, 10:45 PM   #5
Dodge
The DR number was an early California DMV/CHP version of the now CA Tag, when no other number was found on the vehicle or had no paper work.
The pistons look like early Jahns pistons and look used.
I would measure the block, crank and cams to see if they are used or not.
If it is all NOS its worth a whole lot, if used it's just worth a lot.
Dodge is offline   Reply With Quote
Old 10-04-2016, 04:42 PM   #6
ursus
Some interesting information - I have one of the DR-xxxx Model B blocks that came out of California and always wondered about the origin of the number.
Old 10-05-2016, 12:50 AM   #7
Chris Haynes
Chris Haynes's Avatar
Ca use DRF, not DR.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 10-04-2016, 07:02 AM   #8
Kevin in NJ
To get the big money you need to clean them up and measure.
If I were buying I would want to see that all the journals are 100% rust free and new. I would want to know the bore sizes and so on to be sure of two things.
First off is it really new.
Second, make sure it was not a factory oops. Sometimes a part with issues got into the parts stream. Also some of the later production from the 40's were not built to the best standards like production era parts.
So if you want the big bucks, which new will command a premium, you need to clean and measure.
Old 10-04-2016, 07:37 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
Nos crankshafts don't have dowell pins in the flywheel flange, cam gears or keys---I have a NOS A crank, have seen NOS B cranks,
Old 10-04-2016, 10:08 AM   #10
d.j. moordigian
d.j. moordigian's Avatar
The 3rd. photo is 8 pistons,..they are Jahn's pistons,..cast versions. They look used by
the "caramel" on the inside, the pins also look used...
d.j. moordigian is offline   Reply With Quote
Old 10-04-2016, 10:25 AM   #11
Jim Brierley
It is also a diamond block, usually a good thing. I've seen NOS blocks with asking prices of over $1,000. They were still in cosmoline. Russian blocks are easily identifiable by their rough castings and large insignia (?) on the left side.
Old 10-05-2016, 01:40 AM   #12
40Pickup
40Pickup's Avatar
Found this B engine, marine converted. * SR * xxxx
https://www.fordbarn.com/forum/showthread.php?t=198443
Jorgen
40Pickup is offline   Reply With Quote
Old 10-05-2016, 01:48 AM   #13
Dodge
I have a Model A Block and pink slip that has a DR number and a 1938 Harley with a
DR number on the cases and pink slip. So California did use DR numbers. These are also
not the first I have seen.
Old 10-05-2016, 02:15 PM   #14
Chris Haynes
DRF = Department Registry File. CA has used DRF since the '50's that I know of. Possibly earlier it was only DR.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 10-05-2016, 11:38 PM   #15
Dodge
That makes sense the 1938 Harley with the DR number on it had been last registered in 1946. So maybe it was DR then DRF or someone didn't put the F at the end.
