Old 06-10-2016, 09:47 AM   #1
Tgibby
Default Brakes
i have a 41. Ford I am going to put the Lincoln brake set up offered by Bob Drake . Are there any problems I might encounter. They are suppose to be direct bolt ons
Tgibby is offline   Reply With Quote
Old 06-10-2016, 12:16 PM   #2
john in illinois
john in illinois's Avatar
Default Re: Brakes
I am not familiar with Bob Drakes kit,but I have MT Car Lincoln style front brakes on 2 cars. I had to grind the top of spindles to clear the wheel cylinder and then they were bolt on.
They are great brakes and well worth doing.
John
john in illinois is offline   Reply With Quote
Old 06-10-2016, 10:00 PM   #3
19Fordy
19Fordy's Avatar
Default Re: Brakes
I also installed the MT Products complete brake kit on all 4 wheels. No problems.The brakes come in two sizes: 1 3/4 in. wide and 2 in. wide. I bought the 2 in. kit for better stopping power. Also had to grind the top of the front spindle for fitment for the Lincoln backing plate. Made a paper template as a grinding guide. Use your OEM rear wheel bearings if possible as they are better quality than the new China stuff. I also had to cut down the size of the Lincoln E-Brake cable parts to match the 40 OEM.
