Old 04-17-2016, 11:12 PM   #1
1929
Default Brake Energizer kit?
Has anyone here installed this kit? I saw a video where a guy claims he installed the kit on his vehicle, the car stopped on the dime at a high rate of speed. It looked amazing, is it TRUE?
1929 is offline   Reply With Quote
Old 04-18-2016, 12:00 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Brake Energizer kit?
I assume you are talking about Teds.
Teds kit will NOT fix bad brakes.
What you gain is a lighter touch to the pedal but you still need properly installed and adjusted brakes.
Old 04-18-2016, 01:13 AM   #3
Dodge
Doesn't his kit also get the bias moved to the front?
Dodge is offline   Reply With Quote
Old 04-18-2016, 06:30 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Based on my experiences, ....Nope!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-18-2016, 06:40 AM   #5
1929
If one has properly installed and adjusted brakes with all new rebuilt parts, Is Teds kit a plus? is it an additional benefit or not worth the extra $ ?
Old 04-18-2016, 06:44 AM   #6
C26Pinelake
Please show us the kit with price. Wayne
C26Pinelake is offline   Reply With Quote
Old 04-18-2016, 07:13 AM   #7
Kevin in NJ
If you properly redo the brakes restoring the factory tolerances you are likely to find the addition of the Ted's parts just an added complication.
Of course to properly redo the brakes to factory tolerances is not easy, cheap and is something that requires tools most do not have. You are likely better off paying for parts that are properly done.
Old 04-18-2016, 07:13 PM   #8
wmws
If you can lock up all four wheels on pavement your brakes are in good shape. Ted's brakes make it so the forward shoe can be a leading shoe so now you have a double leading shoe system. Sort of like having power brakes. If you don't understand leading shoe trailing shoe you won't understand what I am talking about. I have Ted's system on my car and they work well.
wmws is offline   Reply With Quote
Old 04-18-2016, 07:59 PM   #9
BRENT in 10-uh-C
Could the statement also be said that if you remove 4 springs from the brake shoes, that it will feel like "having power brakes"?
BRENT in 10-uh-C
Old 04-18-2016, 08:20 PM   #10
wmws
No Brent. It has nothing to do with removing the spring. It is the energizing effect of two leading shoes.
Old 04-18-2016, 09:32 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
I like my stock brakes and have never considered changing the system.
I don't see the need for change.
Look what happened with the last hope and change.
Old 04-19-2016, 01:16 AM   #12
Mike V. Florida
If you read the third line of my post "What you gain is a lighter touch to the pedal .." Is a lighter touch worth the money? Only you know.
