The Ford Barn
-   -   Brake Energizer kit? (https://www.fordbarn.com/forum/showthread.php?t=194392)
1929 04-17-2016 11:12 PM
Has anyone here installed this kit? I saw a video where a guy claims he installed the kit on his vehicle, the car stopped on the dime at a high rate of speed. It looked amazing, is it TRUE?
Mike V. Florida 04-18-2016 12:00 AM
Re: Brake Energizer kit?
I assume you are talking about Teds.
Teds kit will NOT fix bad brakes.
What you gain is a lighter touch to the pedal but you still need properly installed and adjusted brakes.
Dodge 04-18-2016 01:13 AM
Doesn't his kit also get the bias moved to the front?
BRENT in 10-uh-C 04-18-2016 06:30 AM
Based on my experiences, ....Nope!
1929 04-18-2016 06:40 AM
If one has properly installed and adjusted brakes with all new rebuilt parts, Is Teds kit a plus? is it an additional benefit or not worth the extra $ ?
C26Pinelake 04-18-2016 06:44 AM
Please show us the kit with price. Wayne
Kevin in NJ 04-18-2016 07:13 AM
If you properly redo the brakes restoring the factory tolerances you are likely to find the addition of the Ted's parts just an added complication.
Of course to properly redo the brakes to factory tolerances is not easy, cheap and is something that requires tools most do not have. You are likely better off paying for parts that are properly done.
wmws 04-18-2016 07:13 PM
If you can lock up all four wheels on pavement your brakes are in good shape. Ted's brakes make it so the forward shoe can be a leading shoe so now you have a double leading shoe system. Sort of like having power brakes. If you don't understand leading shoe trailing shoe you won't understand what I am talking about. I have Ted's system on my car and they work well.
BRENT in 10-uh-C 04-18-2016 07:59 PM
Could the statement also be said that if you remove 4 springs from the brake shoes, that it will feel like "having power brakes"? :confused:
wmws 04-18-2016 08:20 PM
No Brent. It has nothing to do with removing the spring. It is the energizing effect of two leading shoes.
Tom Wesenberg 04-18-2016 09:32 PM
I like my stock brakes and have never considered changing the system.
I don't see the need for change.
Look what happened with the last hope and change.:eek::mad::D
Mike V. Florida 04-19-2016 01:16 AM
If you read the third line of my post "What you gain is a lighter touch to the pedal .." Is a lighter touch worth the money? Only you know.
