31 pickup...i have new oil in my engine, but it has a milky/foamy look to it after running a bit. the engine runs good and i filled the cooling system a few days ago and the water is still up in the radiator neck. i wonder if i may have a bad head gasket or worse. i am going to ga tomorrow and wonder if i should stop by mikes and get a new head gasket just in case. this car sat for probably 30+plus years and i haven't
had the head off as yet, |
Have you checked the head torque?
If you are getting antifreeze coolant into the oil it will remove the lubricity & can cause extensive wear . Water is not so invasive to the lubricity .
i don't know if there is for sure water in the oil, it just doesn't lo0k right, probably less than an hours running on the oil. i've only run water at this point, but will use antifreeze when i am ready to drive it. i'm leaving town tomorrow for ga. and will check the head bolts when get back. i thought i had read something about older head gaskets being a prone to leaking.,
#5 | |
![]() Quote:
Get a gasket, take off the head and see what is going on. Report back with pictures.
When or if you can't find out what is wrong, get in touch with me and I will give you some tips to find the problem.
http://www.model-a-ford-4bangers.com/ |
