Old 06-20-2016, 04:46 PM   #1
1929
Default Stromberg Carb and electric fuel pump?
If you have a Stromberg on your Model A, are you using a fuel pump too?
1929 is offline   Reply With Quote
Old 06-20-2016, 05:03 PM   #2
CarlG
CarlG's Avatar
Default Re: Stromberg Carb and electric fuel pump?
I am currently running my "97" on gravity. Haven't fully decided on whether or not I am going to leave it that way. Have about 250 miles on it so far, and so far - so good. Have the fuel pump and plumbing standing by just in case.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-20-2016, 06:31 PM   #3
emf
emf's Avatar
I ran my stromberg 81's on gravity at first, but I felt I was driving into the wind. I put on a pump and what a difference...
Frank
emf is offline   Reply With Quote
Old 06-20-2016, 09:28 PM   #4
1929
The car runs great until over 65, it seems to run out of gas, so I have to slow down. Iam wondering if the pencil filter in the gas tank, the mesh filter above the glass bowl and nappa filter in the bowl are restricting a bit of the flow. I think 3 filters are overkill.
Old 06-20-2016, 09:45 PM   #5
C26Pinelake
Hopefully the 65 you refer to is degrees Fahrenheit and not mph! Wayne.
C26Pinelake is offline   Reply With Quote
Old 06-20-2016, 10:04 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
My car has 3 filters (2 factory, plus the tank valve filter), and it runs fine with the stock carb. If you run a downdraft, then add a pump if you need to, but I wouldn't eliminate filters.
BTW, why would you even want to drive 65, much less any faster?
Old 06-20-2016, 10:17 PM   #7
1929
only on the highway Tom, when not many others are around
Old 06-20-2016, 10:20 PM   #8
PC/SR
Sounds like it probably does run out of gas. The gravity flow is not able to keep up with the fuel demand at speed. The pump will fix it.
PC/SR is offline   Reply With Quote
