Tom Wesenberg |
06-20-2016 10:04 PM |
Re: Stromberg Carb and electric fuel pump?
Originally Posted by 1929
(Post 1311813)
The car runs great until over 65, it seems to run out of gas, so I have to slow down. Iam wondering if the pencil filter in the gas tank, the mesh filter above the glass bowl and nappa filter in the bowl are restricting a bit of the flow. I think 3 filters are overkill.
My car has 3 filters (2 factory, plus the tank valve filter), and it runs fine with the stock carb. If you run a downdraft, then add a pump if you need to, but I wouldn't eliminate filters.
BTW, why would you even want to drive 65, much less any faster? :confused:
