Old 02-05-2016, 03:00 PM   #1
shoe box Jack
Default pushrod cheater
On the jalopy journal there is a valve timing indexer on u tube. Dose anyone no if this indexer is for sale. Jack.
shoe box Jack is offline   Reply With Quote
Old 02-05-2016, 07:27 PM   #2
Angledrive
Angledrive's Avatar
Default Re: pushrod cheater
Yes, He is making an order. His Handle is CheatersPete from France. If you are not a Hamb member I can get you his email address so you can contact him.
Angledrive is offline   Reply With Quote
Old 02-06-2016, 06:18 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
Contact for information ---
[email protected]
Old 02-06-2016, 07:17 AM   #4
Fordestes
What is a valve guide indexer? I would like to see one , I have dealt with cheaters pete and he is a prince of a gentleman to do business with. very Honest.
Fordestes is offline   Reply With Quote
Old 02-06-2016, 09:35 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by sidevalve8ba View Post
I think this is the device they are referring to:
www.youtube.com/watch?v=45ryUG12Eh8
Jungle Jim, really
Old 02-06-2016, 09:38 AM   #6
sidevalve8ba
sidevalve8ba's Avatar
Oooops! Try this clip instead.
/www.youtube.com/watch?v=Joq_gSXfu6I
sidevalve8ba is offline   Reply With Quote
Old 02-06-2016, 09:40 AM   #7
flatheadmurre
flatheadmurre's Avatar
https://www.youtube.com/watch?v=Joq_gSXfu6I
Old 02-06-2016, 09:44 AM   #8
Tony, NY
Tony, NY is offline   Reply With Quote
Old 02-06-2016, 10:28 AM   #9
34PKUP
34PKUP's Avatar
What is the purpose of this tool??
34PKUP is offline   Reply With Quote
Old 02-06-2016, 11:25 AM   #10
tubman
tubman's Avatar
You use it so you can set the clearances on the valves in your flathead with only 2 rotations of the crankshaft. It's just a timesaver. To a lot of us, the name, "Pushrod Cheater" is kinda misleading, because we are used to "pushrods" as those long skinny things on overhead valve engines. When you remember that Ford referred to the actual valve lifters as "pushrods", things become a lot clearer.
You can do the same thing by setting the valve at it's highest extemsion and then rotating the crank 1 full rotation to set that valve. Since there are 16 valves, this method require 16 rotations of the crankshaft. This cuts turning time by a factor of 8, thus the term "cheater".
Old 03-02-2016, 10:51 AM   #11
Cheaterpete
tool available and ready to ship now, if interested, please send email to [email protected]
thanks
Cheaterpete is offline   Reply With Quote
Old 03-02-2016, 11:28 AM   #12
Joe Immler
51 Merc. Thanks for accidentally sharing Jungle Pam hardy. I remember her from back in the day. HOT !
Joe Immler is offline   Reply With Quote
Old 03-02-2016, 12:49 PM   #13
sidevalve8ba
Actually that was me that accidentally shared that clip but she is fun to look at. That's what happens when you push the wrong button.
Old 03-02-2016, 01:12 PM   #14
Joe Immler
Oops! Well, thank you sidevalve. I sure push a lot of wrong buttons on my computer too.
Old 03-02-2016, 02:23 PM   #15
jack orchard
How much are these here indexers?
Proud FNG
We fixem cars. Heap Good!
jack orchard is offline   Reply With Quote
Old 03-02-2016, 02:56 PM   #16
Andy
I have a couple of old valve indexers like shown in the famous Racer Brown photo. They are for use with the crab distibuters. I actually had made a home made one to work the same. I cut a disk from some sheet metal and marked off the firing order around the rim. I attached with a sleeve and a set screw to the rotor shaft on the crab. I got the engine to TDC and firing on #1 and put a pointer to #1 cylinder on the disk. I figured if the cylinder was firing, the valves would be shut. You only turn the engine two revolutions. Worked fine.
Andy is offline   Reply With Quote
Old 03-02-2016, 08:29 PM   #17
tubman
tubman's Avatar
I paid $68 (sorry for "talking out of school" Pete). I think it's worth it if it will help him in his "enterprise"; who knows what he may come up with next!
Old 03-02-2016, 08:49 PM   #18
Tony, NY
I have one coming but the tracking info is in French.
