The Ford Barn
-   -   pushrod cheater (https://www.fordbarn.com/forum/showthread.php?t=188544)
shoe box Jack 02-05-2016 03:00 PM
pushrod cheater
On the jalopy journal there is a valve timing indexer on u tube. Dose anyone no if this indexer is for sale. Jack.
Angledrive 02-05-2016 07:27 PM
Re: pushrod cheater
Yes, He is making an order. His Handle is CheatersPete from France. If you are not a Hamb member I can get you his email address so you can contact him.
51 MERC-CT 02-06-2016 06:18 AM
Re: pushrod cheater
Contact for information ---
[email protected]
Fordestes 02-06-2016 07:17 AM
Re: pushrod cheater
What is a valve guide indexer? I would like to see one , I have dealt with cheaters pete and he is a prince of a gentleman to do business with. very Honest.
51 MERC-CT 02-06-2016 09:35 AM
Re: pushrod cheater
Originally Posted by sidevalve8ba (Post 1236623)
I think this is the device they are referring to:
www.youtube.com/watch?v=45ryUG12Eh8
Jungle Jim, really:confused:
sidevalve8ba 02-06-2016 09:38 AM
Re: pushrod cheater
Oooops! Try this clip instead. :confused: :D
/www.youtube.com/watch?v=Joq_gSXfu6I
flatheadmurre 02-06-2016 09:40 AM
Re: pushrod cheater
https://www.youtube.com/watch?v=Joq_gSXfu6I
Tony, NY 02-06-2016 09:44 AM
Re: pushrod cheater
34PKUP 02-06-2016 10:28 AM
Re: pushrod cheater
What is the purpose of this tool??
tubman 02-06-2016 11:25 AM
Re: pushrod cheater
You use it so you can set the clearances on the valves in your flathead with only 2 rotations of the crankshaft. It's just a timesaver. To a lot of us, the name, "Pushrod Cheater" is kinda misleading, because we are used to "pushrods" as those long skinny things on overhead valve engines. When you remember that Ford referred to the actual valve lifters as "pushrods", things become a lot clearer.
You can do the same thing by setting the valve at it's highest extemsion and then rotating the crank 1 full rotation to set that valve. Since there are 16 valves, this method require 16 rotations of the crankshaft. This cuts turning time by a factor of 8, thus the term "cheater".
Cheaterpete 03-02-2016 10:51 AM
Re: pushrod cheater
tool available and ready to ship now, if interested, please send email to [email protected]
thanks
Joe Immler 03-02-2016 11:28 AM
Re: pushrod cheater
51 Merc. Thanks for accidentally sharing Jungle Pam hardy. I remember her from back in the day. HOT !
sidevalve8ba 03-02-2016 12:49 PM
Re: pushrod cheater
Actually that was me that accidentally shared that clip but she is fun to look at. :rolleyes: :D :eek: That's what happens when you push the wrong button.
Joe Immler 03-02-2016 01:12 PM
Re: pushrod cheater
Oops! Well, thank you sidevalve. I sure push a lot of wrong buttons on my computer too.
jack orchard 03-02-2016 02:23 PM
Re: pushrod cheater
How much are these here indexers?
Andy 03-02-2016 02:56 PM
Re: pushrod cheater
I have a couple of old valve indexers like shown in the famous Racer Brown photo. They are for use with the crab distibuters. I actually had made a home made one to work the same. I cut a disk from some sheet metal and marked off the firing order around the rim. I attached with a sleeve and a set screw to the rotor shaft on the crab. I got the engine to TDC and firing on #1 and put a pointer to #1 cylinder on the disk. I figured if the cylinder was firing, the valves would be shut. You only turn the engine two revolutions. Worked fine.
tubman 03-02-2016 08:29 PM
Re: pushrod cheater
I paid $68 (sorry for "talking out of school" Pete). I think it's worth it if it will help him in his "enterprise"; who knows what he may come up with next!
Tony, NY 03-02-2016 08:49 PM
Re: pushrod cheater
I have one coming but the tracking info is in French.:confused:
