Old 01-17-2016, 03:09 PM   #1
hazelhoff
hazelhoff's Avatar
Default electrical wiring
Guys,
in need of some guidance here. Have to order wiring stuff. For an early ..1929 tudor. It will need turn lights, but I happen to be a purist. Where what to order.
I built up the car from scratch, so anything is possible.
Buy a combined harness meaning for turn lights included or go for seperate light/turn light wiring.
What suppliers do you recommend ?
Henk
hazelhoff is offline   Reply With Quote
Old 01-17-2016, 05:12 PM   #2
jw hash
jw hash's Avatar
Default Re: electrical wiring
call Snyder`s and talk to there tech, guy. the have the wire harnesses that has the turn signal wires in them. if you add the right hand tail light you can use them in the rear, it is the front that you need to decide where to put them. they will walk you through your options.
jw hash is online now   Reply With Quote
Old 01-17-2016, 06:27 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Do you have fluted headlamps, or the TWOLITE lamps introduced in February 1929?
Do you have a drum taillight?
Sacramento Vintage Ford has the correct full length harness for the drum taillight. I bought two for my 28 and early 29, and they are nice.
I would use original style wiring, then add a separate harness for turn signals, if you install them.
Old 01-17-2016, 10:49 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
What was the last date of the drum tail light on a '29?
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-17-2016, 11:19 PM   #5
ModAfan
ModAfan's Avatar
You might want to see what these folks have to offer.
http://www.narragansettreproductions...parts-ford.pdf
ModAfan is offline   Reply With Quote
Old 01-18-2016, 01:17 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by hazelhoff View Post
Buy a combined harness meaning for turn lights included or go for separate light/turn light wiring.
What is the condition of the wiring you all ready have?
What are you using for the lights?
Adding lights, add wire, most vendors will sell the thread covered wire by the foot.
Existing lights (cowl, headlight parking) get a new harness wired for turn signals.
Old 01-18-2016, 01:25 AM   #7
CarlG
CarlG's Avatar
Sacramento Vintage Ford for all your wiring needs
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-18-2016, 08:02 AM   #8
hazelhoff
hazelhoff's Avatar
Thx Tom,
I have the fluted 1 bulb headlights and will buy drum style rear lights.
Will check Sacramento !
Henk
Old 01-18-2016, 08:07 AM   #9
hazelhoff
hazelhoff's Avatar
Hi Bill,
I remember Jim Schild mentioning april 1929 being the implementation mont of the tea-cup.
Henk
Old 01-18-2016, 08:24 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
I recently wired my 190A restoration, and I highly recommend the main harness that has turn signals built-in.
Bob Bidonde
Old 01-18-2016, 11:05 AM   #11
BILL WILLIAMSON
Hi Bill,
Henk
HMMN! According to my engine number, Vermin is a June '29 Coupe. He has the "D" nuts for a drum tail light, never saw the frame number. The body has been sectioned across the sill plate, "maybe" the rear part of the body was replaced??? Engine I.D. plate has NEVER been re-stamped. OH, the MYSTERY of it all!!!! If my "GHOST" were still around, he could check the FRAME # for me--LOL
Bill W.
Old 01-19-2016, 07:08 AM   #12
hazelhoff
hazelhoff's Avatar
Bill,
My feb. 1929 Tudor came with D nuts as well as fender mounted taillights. Same mystery. Early 1929 Ford had a policy of using up all old parts before going model year 1929. Maybe they took so long changing the sub frame. Maybe the Danisch dealer put fender mounted lights on because he had to deliver a right taillight in Europe
Henk
Henk
Old 01-19-2016, 09:44 AM   #13
Tom Wesenberg
I also have a 29 Tudor body that has the D nuts with screw plugs and has the fender mounted taillight on the left. I don't recall the tank date, but it was March of 1929 I think.
Old 01-19-2016, 11:06 AM   #14
hazelhoff
hazelhoff's Avatar
Hi Tom,
Wha is it that makes you believe having the trun signal harness seperate is the better way ? Just trying to understand before ordering anything.
Henk
Old 01-19-2016, 01:23 PM   #15
Tom Wesenberg
Hi Tom,
Henk
I like to keep the car as original as possible, and by running a separate harness, it would be just like the dealer added an accessory back when the car was new.
It also makes troubleshooting easier if anything goes wrong.
It also makes it cleaner and easier to remove or move location of the lights if someone so desires.
Old 01-19-2016, 02:17 PM   #16
Willie Krash
Willie Krash's Avatar
I agree!
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 01-19-2016, 02:38 PM   #17
hazelhoff
hazelhoff's Avatar
Thx Tom and Mike,
Took just an inch to convince ...
Henk
Old 01-19-2016, 03:14 PM   #18
BILL WILLIAMSON
Vermins' existing "D" nuts would make a good mount for a C.B. antenna or a flag mount or a framed pic of Buster T.
Bill W.
Old 01-20-2016, 12:04 AM   #19
Mike V. Florida
If you want you can wire in your own switch and "hide" it behind the dash panel.
Old 01-25-2016, 09:51 PM   #20
CT Jack
CT Jack's Avatar
I use and highly recommend the turn signal module from Electro-Tech
http://www.turnswitch.com/Turnsignal.htm. This a compact unit that is easy to wire and can be hidden inside your kick panel. It can handle 6V & 12V positive or negative grounds and can operate incandescent or LED lamps. I installed a momentary switch under my dash completely hidden which is used for turning on the left or right turn signals. I use my original cowl lights and tail lights which have LED lights installed in the original sockets. Holding the momentary switch on for 4 seconds turns on the emergency flashing mode. The turn sign on time is adjustable. When you stop and hold your brake on the turn signal keeps flashing. When you release the brake the timer then times out.
CT Jack is offline   Reply With Quote
