Old 01-18-2016, 05:37 PM   #1
leo
leo's Avatar
Question Voltage Test on 6 Volt Battery
OK, I need to test my NAPA 6 volt battery which I just charged. I've got 3 meters that all work but they do not have a 6 volt test setting. I'm so embarrassed, please tell me what to set the meter dial to and how to proceed. As I've previously said I'm really electrically challenged. After the voltage test I will use the hydrometer to check the cells, the tester is glass and has a compensating thermometer float ........
leo is offline   Reply With Quote
Old 01-18-2016, 05:55 PM   #2
mshmodela
mshmodela's Avatar
Default Re: Voltage Test on 6 Volt Battery
In general, set the voltmeter to nearest voltage above what you're attempting to measure, e.g. to measure 6V, set it to 10v or 20v would better than 100v.An analog meter is better than a digital one... Even a cheap analog meter
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
