Old 01-02-2016, 08:46 AM   #1
flathead 53
Default 1953 f-100
was planning to do some body work on my 53 today , started it up to warm it up before bringing it into garage, went in to get a coffee , when i came out oil was pouring out of the breather tube, looks like i am in for a lot more work , other then the body work.
flathead 53 is offline   Reply With Quote
Old 01-02-2016, 09:08 AM   #2
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Re: 1953 f-100
That oil has to come oil pan, up through breather that sticks into the bottom of the intake manifold, then up into the breather tube on the out side of the intake and down the front of the engine and along left side of the oil pan and then out on the ground. If that's where the oil is pouring out there must have a lot of blow by in that engine. Is that correct? Walt
Old 01-03-2016, 07:54 AM   #3
chap52
chap52's Avatar
Start it again tomorrow and see if it's any better...Probably not. Check your plugs (oily?)then compression.
Sounds like you may have a nice winter project ahead.
Keep us posted.
Old 01-03-2016, 08:07 AM   #4
Walt Dupont--Me.
Check oil sender unit on back of block, see if it isn't leaking and oil running along pan rail and dripping off by the draft tube. Walt
Old 01-04-2016, 05:54 AM   #5
flathead 53
added two qts of oil, started engine ,it ran fine 45lbs oil pressure, after a couple of minutes pressure dropped to zero ,i shut down the engine right away,thinking it has to be the oil pump.
Old 01-04-2016, 05:55 AM   #6
flathead 53
oil is definitely coming out of draft tube.
Old 01-04-2016, 06:07 AM   #7
flatheadmurre
flatheadmurre's Avatar
Is the oil in some strange way filling up the gallery and not returning to the pan...
Oiltube in the gallery broken...
If pressure drops instantly and not slowly probably running out of oil.
Old 01-04-2016, 06:37 AM   #8
Diavolo
Diavolo's Avatar
Throwing my hat in there. Your drains in the lifter valley are plugged. Get a new intake gasket, pull the intake and, at minimum, run a rod through the valley drains. If it were me, I would probably pull the pan plug and wash out the lifter valley with kerosene and a stiff brush, then pour some fresh oil through the middle of the valley to make sure the cam has lube.
Then fill, run a sludge remover and drain again, then refill.
Diavolo is offline   Reply With Quote
Old 01-04-2016, 08:17 AM   #9
Walt Dupont--Me.
The 8BA breather tube under the intake sticks up into the manifold about 1/8in. It's possible that someone has installed a 59 breather pipe under the intake and there is gap and some how the oil is blowing up into the tube. Tell us what you find after you pull the intake and the oil pan. Walt
Old 01-04-2016, 08:21 AM   #10
30-9
Could be oil pump bad?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
