Old 11-11-2015, 08:07 PM   #1
Wiresmith
Default '56 F100 Speedometer
Hello All,
I'm in need of guidance. I have a '56 F100 with a stock gauge package. I've installed a T5 transmission from a '95-'97 Mustang with a tag number of 1352-238. I don't know if the speedometer was electronic or analog.
Can anyone point me in the right direction to use this transmission with my stock gauges?
Any help is greatly appreciated,
Mike
Wiresmith is offline   Reply With Quote
Old 11-11-2015, 09:15 PM   #2
paul2748
paul2748's Avatar
Default Re: '56 F100 Speedometer
Do you know what the end that goes into the transmission looked like?
It may have used the cable and gear pictured. Both are available from ebay (and parts stores) but you have to figure out the length of the cable and the number of teeth that you need for the gear (figured using tire size and rear end ratio) I don't know the formula, hopefully some one here can give it to you.
There are similar cables with a different end that goes into the trans so I don't know which the trans used.
The gear goes on the cable and is held on by a clip. For some electronic you can replace it with the mechanical cable and gear.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 11-11-2015, 10:11 PM   #3
miker98038
miker98038's Avatar
I bought a couple tremec's from these guys, the T-5 is in my 'bird. They knew it all in their sleep if you've got a tag number. Might try a phone call.
http://www.ddperformance.com
miker98038 is offline   Reply With Quote
