Old 09-28-2015, 03:35 PM   #1
Shovel
Default 26 T pickup
well got the T, and I am a first time T owner (all manuals are on order)...time to commence with some stupid questions...
1.what is this, it isn't connected to anything
2.can anyone I.D. this distributor..wobbles and is missing rod that goes to the timing advance lever, need to order one
3. what are these...they were in my parts pile??
thanks!!
Shovel is offline   Reply With Quote
Old 09-28-2015, 04:10 PM   #2
tmodelman
Default Re: 26 T pickup
The bracket on the rear of the cylinder head is likely for a foot throttle accessory.
Can't id the dizzy.
Those pans are Model A dust pans for between the motor and frame.
tmodelman is offline   Reply With Quote
Old 09-28-2015, 04:39 PM   #3
yachtsmanbill
yachtsmanbill's Avatar
Thats an after market distributor, with more than likely a BOSCH #9 head on it (VW's used them). There may or may not be a centrifugal advance inside. At any rate, theres a link of "bell crank" missing, which you may or may not need depending on the above. Look DEEP inside mine... see the spring (yellow?). ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!"
yachtsmanbill is offline   Reply With Quote
Old 09-28-2015, 04:45 PM   #4
yachtsmanbill
... pretty standard tune up stuff too... ws
Old 09-30-2015, 08:24 AM   #5
Shovel
can get it to fire and run for a few seconds ...will not stay running(guessing fuel)....that is the same distributor i have...haven't looked inside yet to see if it is mechanical advance....need some windshield parts also
