Old 08-11-2015, 01:08 PM   #1
chopnchaneled
Default B counter balanced crank ?
Hi All
I've got an extra B crank thats standard on the mains and rods, but it looks like due to some pitting, it will at least have to be polished or turned 5 or 10 th's.
I have a couple folks that want it, My question is so that nobody gets
hurt what do you think a going price should be?
Thanks
Joe
chopnchaneled is offline   Reply With Quote
Old 08-11-2015, 04:21 PM   #2
Chris Haynes
Chris Haynes's Avatar
Default Re: B counter balanced crank ?
If they want to put it in an A it need to be ground undersized anyway.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 08-12-2015, 08:06 AM   #3
chopnchaneled
Thanks Chris, forgot about that.
Like i said i just want to be fair.
Old 08-12-2015, 10:23 AM   #4
Jim Brierley
If it is a "C" crank, with the counterweights part of the forging, it can be worth up to $400.If it is the early "B", a lot less, no more than $100. The smaller (more undersized) the less value.
Old 08-12-2015, 11:29 AM   #5
wrndln
I thought a B crank had counter weights and bigger bearing journals. Am I wrong? I don't know much about model B's - I knew C cranks have counter weights.
Rusty Nelson
Old 08-12-2015, 01:16 PM   #6
Fullraceflathead
Fullraceflathead's Avatar
I believe the early "B" cranks had "Press Fit" counter weights on them.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 08-12-2015, 01:44 PM   #7
chopnchaneled
The counter weights are part of the forging on it.
Old 08-12-2015, 01:49 PM   #8
Pete
Some B cranks had press on weights. Sometimes known as BB cranks.
These are very desirable for race engines.
Old 08-12-2015, 09:26 PM   #9
Fullraceflathead
That makes a lot more sense. Make a press on weight to use on all the standard cranks already made. I wish I had a set of the press on counter weights to use on my standard crank.
-Henry Ford
1941 Willy's Pickup
Old 08-12-2015, 09:39 PM   #10
Pete
Email Dan Price. He makes them.
[email protected]
Old 08-12-2015, 10:39 PM   #11
Benson
Here is a series of photos that shows the B , "BB" and "C" cranks which I took in 1976 while building a B block with full oil pressure and drilled "C" crankshaft for a Miller overhead valve engine.
I know there is no such thing as a C crank but many folks call them that.
Film must have been Plus-X or Tri-X B/W film.
Sorry Vince if this duplicates postings on your website but I did not find any such photos when I quickly looked there.
1. First photo is of the "C" and standard B crank.
2. Second photo is of the "C" and "BB" cranks.
3. Third photo is of the drilled "C" crank this crank is STD Rods and STD mains.
Looks like you must have Adobe Reader installed to see photos.
Old 08-13-2015, 12:37 AM   #12
40 Deluxe
Benson, Is that drilled "C" crank still STD.-STD.?
