Are the Ford script spring shackles with no cotter pin hole and drive in grease fittings correct for judging purposes on any year Model A Ford?
No all shackles would have cotter pin holes. If these are used look real close, sometimes the nut was turned off and sheared the cotter pin. Because of how A shackles are installed the cotter pins is needed.
Those NOS were Ford service and did not have holes so no sheared off cotter pins. Don't know why they did that unless they had lock nuts. Fine point judging would require cotter pins as that's how they came originally so you'll have to drill them usually with carbide since they're hardened.
When did Ford stop using cotter pins in the service replacement shackles for the A?
Rusty Nelson |
