Les specifies ring gaps as .012-.015 for top; .010-.012 for middle. .008-.010 for bottom.
Tbirdtbird specifies .022 top; .-016-.018 for middle. I used Les's when I put my engine together. I didn't have Tbird's specs at that time. The engine seems pretty tight when it's warmed up. Now I'm wondering if I should tear it down and reset the gap. These are significantly different. Can anyone explain that? See 5/21/15 followup below.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() Last edited by 700rpm; 05-23-2015 at 06:54 PM. Reason: Followup to original thread |
