Old 05-23-2015, 02:45 PM   #1
31 Model A
31 Model A's Avatar
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Default Cross bar bolts...........
Are the cross bar bolts also suppose to take the luggage rack supports? I tried but I might not have done something right and it has been playing on my mind that the luggage rack when down should be closer to the body. The photo is deceiving because the bracketets have an opening to take bolts closer together on one side.
This came from Mac's and it shows the crossbar bolts which tell me something is not right either with the brackets I have of operator headspace.
http://www.macsautoparts.com/assets/...cs/A18575B.pdf
31 Model A is offline   Reply With Quote
Old 05-24-2015, 12:03 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Cross bar bolts...........
Where is your spare? Most A's have them on the rear as you know. The extension arms allow the rear spare to stay against the car and the trunk beyond that. If you have the spare on the front the extension arms are not needed.
Old 05-24-2015, 07:25 AM   #3
31 Model A
31 Model A's Avatar
Mike, I don't have a spare mounted there and there is no extensions brackets. It is how it's shown in Mac's diagram, lower left but the brackets are bolted to two fwd holes and not with the two back cross bar bolts. I wonder if I have the wrong brackets of just mix-matched holes. I believe my box sits farther out than it's suppose to when not mounted in front of a spare even though I have no extensions arms. I think I'll call Mac's since it's his diagram showing the brackets to be bolted with the crossbar bolts.
Thanks.........
Old 05-24-2015, 02:11 PM   #4
Mike V. Florida
You see the "silver" bar in your picture? On my car that rests about 1/2 inch from my spares hub cap.
Old 05-24-2015, 02:24 PM   #5
31 Model A
31 Model A's Avatar
When my rumble is open, there is eight inches from it to the backside of my box. Here is a photo I came across showing the box much closer to the rumble.
Old 05-24-2015, 03:28 PM   #6
31 Model A
31 Model A's Avatar
Mike, I took the box off and the rack and took this photo of all four holes. If you look at Mac's installation diagram, the arrow points to the two back holes that also hold the crossbar on.
Mac's diagram:
Old 05-24-2015, 09:09 PM   #7
31 Model A
31 Model A's Avatar
Got the brackets into the FWD holes and the box now is 3.5 inches from an open rumble instead of eight inches. The rack was installed by the previous owner. Much better, doesn't stick out like a sore thumb now. I must have the only Coupe with a luggage box without a spare tire.
Old 05-25-2015, 12:21 AM   #8
Mike V. Florida
Glad you got !!
Old 05-25-2015, 12:26 PM   #9
31 Model A
31 Model A's Avatar
Glad you got !!
What was confusing me Mike was the previous owner used the holes for rack extensions for a Coupe with a rear tire instead of the front holes for a Coupe with no spare tire. I knew there was no rack extensions but the holes were being used.
