The Ford Barn
-   -   Cross bar bolts........... (https://www.fordbarn.com/forum/showthread.php?t=169429)
31 Model A 05-23-2015 02:45 PM
Are the cross bar bolts also suppose to take the luggage rack supports? I tried but I might not have done something right and it has been playing on my mind that the luggage rack when down should be closer to the body. The photo is deceiving because the bracketets have an opening to take bolts closer together on one side.
This came from Mac's and it shows the crossbar bolts which tell me something is not right either with the brackets I have of operator headspace.
http://www.macsautoparts.com/assets/...cs/A18575B.pdf
http://i59.tinypic.com/qozwxy.jpg
Mike V. Florida 05-24-2015 12:03 AM
Re: Cross bar bolts...........
Where is your spare? Most A's have them on the rear as you know. The extension arms allow the rear spare to stay against the car and the trunk beyond that. If you have the spare on the front the extension arms are not needed.
31 Model A 05-24-2015 07:25 AM
Mike, I don't have a spare mounted there and there is no extensions brackets. It is how it's shown in Mac's diagram, lower left but the brackets are bolted to two fwd holes and not with the two back cross bar bolts. I wonder if I have the wrong brackets of just mix-matched holes. I believe my box sits farther out than it's suppose to when not mounted in front of a spare even though I have no extensions arms. I think I'll call Mac's since it's his diagram showing the brackets to be bolted with the crossbar bolts.
Thanks.........
Mike V. Florida 05-24-2015 02:11 PM
You see the "silver" bar in your picture? On my car that rests about 1/2 inch from my spares hub cap.
31 Model A 05-24-2015 02:24 PM
When my rumble is open, there is eight inches from it to the backside of my box. Here is a photo I came across showing the box much closer to the rumble.
http://i62.tinypic.com/4k8cae.jpg
31 Model A 05-24-2015 03:28 PM
Mike, I took the box off and the rack and took this photo of all four holes. If you look at Mac's installation diagram, the arrow points to the two back holes that also hold the crossbar on.
http://i58.tinypic.com/24xl0jm.jpg
Mac's diagram:
31 Model A 05-24-2015 09:09 PM
Got the brackets into the FWD holes and the box now is 3.5 inches from an open rumble instead of eight inches. The rack was installed by the previous owner. Much better, doesn't stick out like a sore thumb now. I must have the only Coupe with a luggage box without a spare tire.
Mike V. Florida 05-25-2015 12:21 AM
Glad you got !!
31 Model A 05-25-2015 12:26 PM
Originally Posted by Mike V. Florida (Post 1091526)
Glad you got !!
What was confusing me Mike was the previous owner used the holes for rack extensions for a Coupe with a rear tire instead of the front holes for a Coupe with no spare tire. I knew there was no rack extensions but the holes were being used.
