1930 fordor...
1. What are you supposed to do about the nut on each side that goes between the gasket and the frame? Seems there is not room for both. The only options seems to be to force it in and distort the gasket. Or should I stop the gasket short of the screw/nut? 2. How do I finish the corners? Cut each at a 45 degree angle? Then attempt to glue them? Leave them alone? Last edited by freak; 04-26-2015 at 05:15 PM. |
