Old 04-25-2015, 09:51 PM   #1
kressej
kressej's Avatar
Default Optima battery holder
Got an Optima battery recently. Made my own holder out of 3/4" plywood and deed a board under it with two sideboards to keep it in place. Thought you might want to see it. No chance of shorts, no metal top bracket.
kressej is offline   Reply With Quote
Old 04-25-2015, 09:55 PM   #2
kressej
kressej's Avatar
Default Re: Optima battery holder
Here's the finished product:
Old 04-25-2015, 10:04 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Nice work!! I can think of several different materials that would work with that design.
Old 04-26-2015, 12:11 AM   #4
Christoph
Christoph's Avatar
Really - nice work !!!!
I did a 2-minute-prob-fixed-solution (back in time) as i
didnt like "original" holddown from the vendors either.
Just cut out of thin plastic-plates. This should reduce
chance of shorts too.
Christoph is offline   Reply With Quote
Old 04-27-2015, 09:47 AM   #5
Rojo
Looks really nice! Maybe a dumb question but what is holding the battery down? I use an Optima also and am using the Bert's metal top holder on the original battery tray. i must be missing something from the pic but looks like the battery is just sitting in that cutout in the plywood and doesn't appear to have anything holding it down.....of course my old pilot eyes are not nearly as good as they were a few years back!
Rojo is offline   Reply With Quote
Old 04-27-2015, 02:42 PM   #6
Redbird
Redbird's Avatar
Looks like hold down nuts at the 2:00 o'clock and 8:00 o'clock position.
Redbird is offline   Reply With Quote
Old 04-27-2015, 02:47 PM   #7
CarlG
CarlG's Avatar
It also looks like those nuts only serve to hold down the plywood, but not the battery itself.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-27-2015, 03:03 PM   #8
Rojo
Exactly what I thought, CarlG.
Old 04-27-2015, 07:08 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
I used what I had--worked good for the 16 yearts the Optima lasted
Old 04-27-2015, 08:35 PM   #10
daveymc29
daveymc29's Avatar
I bought the bracket from a vender. It didn't fit so I bent it until it does fit. Not the best answer probably, but it works real well, holds the Optima in place and prevents any movement as I drive over our roads, some of which aren't the best.
daveymc29 is offline   Reply With Quote
Old 04-29-2015, 12:56 PM   #11
kressej
kressej's Avatar
I don't have a top strap because the battery can only go up about an inch before it hits the floorboards. The battery is sitting on a piece of 3/4" board with 3/4" side rails to hold it from moving side to side.
