Old 04-06-2015, 10:05 AM   #1
Jwilli
Jwilli's Avatar
Thumbs up Thanks to Tom Wessenberg
Tom, I have followed your advise on two items, It worked on both. On the timing gear I followed the picture that you had posted. Checked the timing on the engine. Engine started after about two revolutions, runs good.
On the broken steering arm, I compressed the ball and spring with a large C clamp then put a very small C clamp on the ball cup. Put the shaft in a vise and was able to use a large screw driver to pry the ball and shaft out. I followed your advise and wore leather gloves and face shield.
It was installed wrong.
Thank you for your knowledge of the A, and your willingness to share.
Jwilli is offline   Reply With Quote
