35 P.U,Bottom radiator hose fit
Have installed a 1946 59A engine in my 35 pickup and am in the process of connecting up the radiator and hoses. As you can see in the picture the bottom radiator outlet pipes are pointing upwards and not lined up with the openings on the 59A block. since the length of the hose will only be approx. 5" I,m concerned about this connection and leaks.
Has anyone experienced this problem ?. Thanks
Lineman, the only dumb animal that can harness himself !!
