Old 03-26-2015, 08:21 PM   #1
Redbird
Redbird's Avatar
Default Rumble Step Plate
See pictures. There is a crack in the outer rim of the step plate. It also spins when you go to step up into the rumble seat. Is this a threaded bolt or pressed on? I would like to take apart to clean up and stop from spinning.
Redbird is offline   Reply With Quote
Old 03-26-2015, 08:31 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Rumble Step Plate
it just threads in, a carrige bolt, clean it up and locktite it---but eventually someone will spin on it and it will come loose again, it happens on my car every 5-10 years---a lot of people have been in and out and many it is the first time so they don't quite get how to use the steps
Old 03-26-2015, 09:06 PM   #3
Redbird
Redbird's Avatar
The bolt will not back out. The step plate spins. The square hole must be rounded out.
Old 03-26-2015, 11:05 PM   #4
Goldhardt
Goldhardt's Avatar
I think that I would just forget about the step plate for now and drink that bottle of wine in the background of your picture!
Goldhardt is offline   Reply With Quote
