The Ford Barn
-   -   Rumble Step Plate (https://www.fordbarn.com/forum/showthread.php?t=164841)
Redbird 03-26-2015 08:21 PM
Rumble Step Plate
2 Attachment(s)
See pictures. There is a crack in the outer rim of the step plate. It also spins when you go to step up into the rumble seat. Is this a threaded bolt or pressed on? I would like to take apart to clean up and stop from spinning.
Kurt in NJ 03-26-2015 08:31 PM
Re: Rumble Step Plate
it just threads in, a carrige bolt, clean it up and locktite it---but eventually someone will spin on it and it will come loose again, it happens on my car every 5-10 years---a lot of people have been in and out and many it is the first time so they don't quite get how to use the steps
Redbird 03-26-2015 09:06 PM
The bolt will not back out. The step plate spins. The square hole must be rounded out.
Goldhardt 03-26-2015 11:05 PM
I think that I would just forget about the step plate for now and drink that bottle of wine in the background of your picture! :rolleyes:
