Old 02-24-2015, 01:19 PM   #1
motordr
Default Brake Adjusting Shaft A-2042
How critical is the length of the brake adjusting shaft A-2042? I would think that both sides on each backing plate should be equal, so what would be an acceptable variation in length?
I plan to use woven linings that are bonded to the shoe, is there any history of the bond not holding?
motordr is offline   Reply With Quote
Old 02-24-2015, 01:38 PM   #2
tbirdtbird
Default Re: Brake Adjusting Shaft A-2042
They should be the same length.
For some reason the 'pointed edge' (really the forging line where the 2 dies come together) is usually worn down making it hard for the adjusting cone to 'click' properly.
I usually dress the 2 slanted surface on a grinding wheel. At the same time i use a dial caliper to check the length and grind as needed so that I have pairs of equal length; else you will not have even application of the shoes. A very easy task actually.
Not sure how well the bonding process would work with woven linings. Why take a chance? Riveting them on is not hard, and works very well.
'31 180A
tbirdtbird is offline   Reply With Quote
Old 02-24-2015, 01:42 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I've never seen a bonded shoe come off while a car is in service, but my Corvair was parked for a year or so and the bonded linings came off.
Old 02-24-2015, 01:56 PM   #4
tbirdtbird
Tom, I have seen bonded shoes fail in service. it ain't pretty
'31 180A
Old 02-24-2015, 02:01 PM   #5
Mitch//pa
i have also,,,
plus the bonded linings cob web / heat crack due to lack of heat dissipation
Old 02-25-2015, 07:42 PM   #6
motordr
Anyone know the factory tolerance on the length of the brake adjusting shaft?
