Old 02-02-2015, 03:50 PM   #1
art
Question 1965 Mustang 289 V8 4.7L
Does anyone know the correct part number for the front wheel (drum brake)cylinder for the title car?
art is offline   Reply With Quote
Old 02-02-2015, 09:13 PM   #2
paul2748
paul2748's Avatar
Default Re: 1965 Mustang 289 V8 4.7L
Just go to NAPA and ask for a 65 Mustang wheel cylinder.
Old 02-03-2015, 01:04 PM   #3
ponymare
It might get a little more complicated than just asking for the cyl, might have to know the drum size, V8 or 6 cyl, and the size of the cyl bore. It will say on the rubber cup inside, like 7/8, 15/16, 21/32.
ponymare is offline   Reply With Quote
Old 02-04-2015, 08:22 PM   #4
raceron1120
raceron1120's Avatar
Looks like the correct Ford #s are - Right side: C5DZ-2061-A. Left side: C5DZ-2062-A.
BUT there are others that might also work. These numbers appear to be the ones used at the time of production but obsolete/supersede/interchanges take place frequently so others may be listed as well.
raceron1120 is offline   Reply With Quote
Old 02-06-2015, 12:27 PM   #5
art
Thank you all for your input. I have my problem solved
Art
Old 02-17-2015, 04:29 PM   #6
mobileparts
Footnote -- if you value your car -- I have some N.O.S. Front & Rear ++ Asbestos ++
Brake Shoes for these:
Fronts are 10" x 2 1/4" and Rears are 10" x 1 3/4".......
I also have the 390 & 428 applications where they "beefed it up" and did
10" x 2 1/2" in the Fronts and 10" x 2" in the Rears.....
At the moment -- have all of the above in N.O.S. ++ asbestos ++ !!!!!!!!!!!!!!!!
mobileparts is offline   Reply With Quote
