Old 02-09-2015, 03:48 PM   #1
V4F
V4F's Avatar
Default oil pan problems
1931 model "A" motor . I have an oil pan snivel (leak) . ive had the pan off several times but still leaks . have another pan coming . which pan gasket are most of you having good luck with ? any ideas appreciated ... steve
V4f
V4F is offline   Reply With Quote
Old 02-09-2015, 04:04 PM   #2
Brentwood Bob
Default Re: oil pan problems
engine pan flange needs to be flat. I use cork that I soak in water, then spray paint with aluminum paint.
There are threads(previous discussions) on installing the pan.
no torque wrench, snug is good. If you squeeze out the gasket you distorted it, and it will respond by probably leaking.
the original pan bolts will fracture if too tight.
I use pieces of cotten butcher string to hold the gasket in the correct position to install. put the front end on good, strong engine stands so you can swing the front wheels from side to side to access the front bolts.
I have a little extra trouble installing the flywheel inspection plate.
Bob
Brentwood Bob is offline   Reply With Quote
Old 02-09-2015, 07:02 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Is the drain plug leaking? Are there pin holes in the pan?
Both can be soldered, brazed, or welded.
Old 02-09-2015, 11:51 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Old style cork not the new rubberized one. If you insist on using the rubberized one READ THE DIRECTIONS several times. Very little torque on the bolts is needed.
Old 02-10-2015, 03:27 PM   #5
V4F
V4F's Avatar
the rear of my old pan was sharp & cutting the cork . another pan on the way . thanks much to all ....... steve
V4f
Old 02-10-2015, 05:24 PM   #6
Tiny
Tiny's Avatar
http://www.sacramentocapitolas.org/s...et-Article.pdf
This worked for me
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 02-10-2015, 11:18 PM   #7
V4F
V4F's Avatar
that is really cool . thank you for your help ............ steve
V4f
Old 02-11-2015, 12:02 AM   #8
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
The guy who came up with this and who's hands are in the picture, is the person that built my engine. Including the babbit. It took a while, but it's a hell of an engine. ( not the writer)
Old 02-11-2015, 09:11 AM   #9
V4F
V4F's Avatar
thanks chuck ............ steve
V4f
Old 02-11-2015, 10:37 AM   #10
FrankWest
FrankWest's Avatar
Originally Posted by Tiny View Post
This worked for me too...
Thanks Tiny.....
Also
the permetex aviation gasket sealer is the stickest and lasting stuff I ever have seen.
FrankWest is offline   Reply With Quote
Old 02-11-2015, 10:43 AM   #11
Arlyn Bieber
Forget the gaskets, use RTV
Arlyn Bieber is offline   Reply With Quote
Old 02-11-2015, 12:41 PM   #12
Tiny
Tiny's Avatar
No problem Steve. I'm always happy to share.
Blackwall Panthers
Nor Cal chapter
