Old 11-19-2014, 01:54 PM   #1
M. Philips
M. Philips's Avatar
Default Rims
Is there a online shop where I can order rims for my model a?
Don't have to be wire wheels.
grtz
M. Philips is offline   Reply With Quote
Old 11-19-2014, 02:01 PM   #2
CarlG
CarlG's Avatar
Default Re: Rims
Most of the vendors sell the correct new wire wheels, as does Coker tire.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-19-2014, 03:14 PM   #3
Ford1931
Ford1931's Avatar
Default Re: Rims
All kinds of rims will bolt to the Model A. Used rims should be easy to find. The new Model A rims are very true and well balanced and are of great quality. The down side is that they are costly, over $300 each.
Ford1931 is offline   Reply With Quote
Old 11-19-2014, 04:57 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Rims
Full size Ford truck wheels use to fit, probably still will. Berts in denver has good used model A wheels that I would rather have any day compared to the expensive new repro wheels. I have used both. Call Berts, tuesday through saturday at noon. 800-321-1931
Old 11-19-2014, 05:20 PM   #5
Charlie Stephens
Default Re: Rims
Remember if you use late model solid rims with mechanical brakes ('40-'48 Ford among others) you will probably need adapters. The bolt pattern is the same but the early wire wheels and brake hubs/drums are actually at 2 levels. See: http://www.jalopyjournal.com/forum/t.../#post-8330045
Charlie Stephens
