Old 11-11-2014, 06:58 AM   #1
Kevin - Illinois
Kevin - Illinois's Avatar
Question Overdrive cable connection
I know where the overdrive cable connects to the transmission, but where is the correct position for the bracket and handle in a 53 Customline? I picture would be helpful.
Thanks,
Kevin
Kevin - Illinois is offline   Reply With Quote
Old 11-11-2014, 07:40 AM   #2
Cecil/WV
Cecil/WV's Avatar
Default Re: Overdrive cable connection
All that I have seen, including a '55 Ford, the bracket fastens on with the top bolt on the solenoid.
Cecil/WV is offline   Reply With Quote
Old 11-11-2014, 08:24 AM   #3
itsa52
itsa52's Avatar
This what you looking for? https://www.google.com/url?sa=i&rct=...15798552311986
itsa52 is offline   Reply With Quote
Old 11-11-2014, 08:58 AM   #4
Johnnydidd
Johnnydidd's Avatar
On my 53 victoria the T handlr is next to the steering column on the right hand side.
Johnnydidd is offline   Reply With Quote
Old 11-11-2014, 12:40 PM   #5
itsa52
itsa52's Avatar
On my Merc there is an oval hole with rubber sleeve in the firewall, probably about inline with the exhaust on the driver's side.. The handle for the cable is directly in back of that so there are few bends in the cable.
Old 11-11-2014, 10:15 PM   #6
Kevin - Illinois
Just what I was looking for! Thank you itsa52!
Old 11-11-2014, 11:19 PM   #7
Richard in Florida
Richard in Florida's Avatar
Does this help? Sorry it's not very clear.
Richard in Florida is offline   Reply With Quote
Old 11-12-2014, 07:52 AM   #8
Cecil/WV
Cecil/WV's Avatar
Looks like I misunderstood the question, I should pay attention to what I am reading.
Old 11-12-2014, 08:13 AM   #9
itsa52
itsa52's Avatar
I am always getting in trouble for not reading the last paragraph. Must be an age thing...lol
Old 11-12-2014, 02:25 PM   #10
charles in east texas
charles in east texas's Avatar
Don't forget about the bracket held by a bell housing bolt. On the firewall as mentioned there is an oval "knock out" for the cable to go through, but I just drilled a hole in the middle of the oval rather than having a much larger hole. Also a small "knock out"
for the kick down switch located under the accelerater pedal. Charles
charles in east texas is offline   Reply With Quote
