Old 09-28-2014, 03:19 PM   #1
dave m
Default shock link removal ?
anybody--- got any sugestions for removing front dog bones from the shock arm & perch pins soaked both them in oil tried brass hammer but no luck real stubborn little buggers---thanks
dave m is offline   Reply With Quote
Old 09-28-2014, 03:30 PM   #2
V12Bill
V12Bill's Avatar
Default Re: shock link removal ?
Remove the nuts, strike the perch with a 3 or 4# hammer where the link is bolted and the tapered pin should pop out. Do the same with the shock arm, backing it up on an anvil and it should pop out also.
V12Bill is offline   Reply With Quote
Old 09-28-2014, 03:42 PM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
Here is a similar post with some suggestions....
https://www.fordbarn.com/forum/showth...ove+shock+link
John
Old 09-28-2014, 03:42 PM   #4
Kube
Kube's Avatar
If you don't plan on reusing them, a tie rod end removal tool (aka: pickle fork) will make easy work of it.
If you want to reuse them, you'll need a tie rod end removal press tool.
Old 09-30-2014, 09:34 PM   #5
38Tudor
38Tudor's Avatar
I second the Pickle Fork, on a Air Hammer.
"Thrifty Sixty"
Ford V8 for 1938
38Tudor is offline   Reply With Quote
Old 10-01-2014, 05:21 PM   #6
Don
Don's Avatar
Bruce had Same problem,,a litte heat using small torch,about 1/4 wide strip red hot ,a light tap with hammer and they popped right out,put a nut on first ,just a few treads to protect the link threads
DON P
Don is offline   Reply With Quote
