Old 08-17-2014, 11:02 PM   #1
Floats
Floats's Avatar
Default A/B diff swap
Hi Gents,
I want to put a faster diff in my 28 Roadster Pickup.
Are the rear axles of all the Model As the same dimensions and can I use a B rear end and up to what year?
Regards
Chris
Floats is offline   Reply With Quote
Old 08-17-2014, 11:21 PM   #2
quickchange
quickchange's Avatar
Default Re: A/B diff swap
early 32 same internals, There are a number of ring & pinnion ratios avalible , or you can fit a Qickchange & have any final ratio you want . Mitchell over drive works well. plus some 4---5 speeds ,
quickchange is offline   Reply With Quote
Old 08-20-2014, 02:19 PM   #3
Charlie Stephens
Originally Posted by Floats View Post
Hi Gents,
Regards
Chris
The spring on the B rear end mounts behind the axle. Just get the right gears for the A rear end. As noted in the previous the 1932 (except very late) gears are the same as a Model A and can be used.
Charlie Stephens
Old 08-22-2014, 06:49 AM   #4
Floats
Floats's Avatar
Tks gents,
Have a good weekend.
Regards
Chris
