A/B diff swap Hi Gents,
I want to put a faster diff in my 28 Roadster Pickup. Are the rear axles of all the Model As the same dimensions and can I use a B rear end and up to what year? Regards Chris |
Re: A/B diff swap early 32 same internals, There are a number of ring & pinnion ratios avalible , or you can fit a Qickchange & have any final ratio you want . Mitchell over drive works well. plus some 4---5 speeds ,
Re: A/B diff swap Quote:
Charlie Stephens |
Re: A/B diff swap Tks gents,
Have a good weekend. Regards Chris |
