Old 04-07-2014, 01:46 PM   #1
FlatheadTed
FlatheadTed's Avatar
Default Brake adjustment
Optimum clevis arm angle .While Adjusting a Model A brakes I noticed the clevis arm was pre-set at 10 degrease forward ,setting it at another 15 deg would give you a better starting point .Just something to be aware of , the king pin push rod has a groove in it from I think a re popped king pin with the hole to small.
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 04-07-2014, 01:48 PM   #2
FlatheadTed
Default Re: Brake adjustment
Push rod
Old 04-07-2014, 03:50 PM   #3
Joe K
Joe K's Avatar
Or the groove could have been formed at the bottom when the wedge got "crooked" and pulled the rod over to the side. A bound shoe on one side can cause this.
This guy have "floaters?"
Joe K
Shudda kept the horse.
Old 04-07-2014, 07:35 PM   #4
glenn in camino
glenn in camino's Avatar
I make my own pushrods out of 5/16" round rod About 3/16" to 1/4" longer than the stock rods.
Old 04-07-2014, 08:02 PM   #5
spdway1
spdway1's Avatar
Joe K
YEA, your talking to Flathead Ted, the brake conversion king!
spdway1 is offline   Reply With Quote
Old 04-07-2014, 08:19 PM   #6
Joe K
Joe K's Avatar
That true, but maybe this one didn't have them yet?
And a lateral movement of the wedge (that IS what floaters allow isn't it?) might lead the pin to wear on the edge where it passes through the backing plate.
Joe K
