I am helping a friend work on his 1930 coupe and found this unusual brake drum / hub. Can anyone identify it?
Chris
" . . . these changes aren't permanent, but change is." - Neal Peart |
Commonly called the Rocky Mountain brake drum. Is it 12" or 11"?
It's cast iron so it doesn't have the brake fade of the steel drums. Last edited by Tom Wesenberg; 03-29-2014 at 09:58 AM. |
I have two (2) original brake drums that look very similar on my Model B front axle that my Uncle used to make a boat trailer in 1932 -- think the drums are 12" inside diameter -- never removed them since 1960 or 54 years ago ............ CRS could be possible after 50 years in many cases.
Used on new cars late in 31. Better than the solid drum.
Brian SATX |
If the inside diameter is arround eleven inches it is a late 31 cast iron drum. If it is 12 inch inside diametyer it is 32 or later.
Chris
I have 3 of them and can tell by the amount of material just passed the 5 spokes that it is an 11" drum. Nice find.
Wanted: Simmons Super Power Head ![]() Craig Likon 1931 150B |
